What Is This 3" Inch Pvc Pipe For? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 08:10 PM   #1
Rewards Points: 33
What is this 3" inch pvc pipe for?
At the top of the picture, please see the 3" diameter pvc pipe. It seems to run inside the wall behind the toilet up to the ceiling then it makes a 90 degree turn and heads through the ceiling to some unknown destination.
What do you think it's for? Water? Gases?
shinyhalo is offline   Reply With Quote
Old 01-03-2013, 08:16 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
waste stack, vent stack or radon vent? Prolly waste stack
Old 01-03-2013, 08:16 PM   #3
bbo
sure, one or the other.
bbo is offline   Reply With Quote
Old 01-03-2013, 08:21 PM   #4
Rewards Points: 13,300
Just look in the attic to see if it does run up through the roof like it should.
Old 01-04-2013, 01:07 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,112
+1
That or look on the roof if you can see it from outside.
Probably a main vent stack.
Old 01-04-2013, 07:25 AM   #6
PoleCat's Avatar
Rewards Points: 1,646
There could also be a hidden toilet in the attic. But odds are it is a vent.
PoleCat is offline   Reply With Quote
Old 01-04-2013, 10:12 AM   #7
Raccoon needs a place to go as well.
Old 01-04-2013, 12:06 PM   #8
Rewards Points: 956
lol and squirels!
federer is offline   Reply With Quote
Old 01-07-2013, 12:43 PM   #9
I knew of a cat that would use a toilet, but never a squirrel!
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 06:53 AM
need flange for 7 inch chimney pipe beech HVAC 7 12-09-2012 09:34 AM
four inch plastic drain pipe through concrete foundation wall dan patterson Plumbing 11 01-25-2011 07:23 AM
half Inch gas pipe Jim Skyblue Plumbing 3 01-04-2011 10:33 PM
(pic) cutting 3" pvc pipe with helpmefolks Plumbing 13 03-31-2009 06:10 PM
