Wet Insulation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-10-2008, 08:28 AM   #1
wet insulation
I found wet insulation in a bedroom. I pulled the paneling off and there it was. Since i fixed my roof do I need to replace ext.wall as well?
Boyll'd Pepper is offline   Reply With Quote
Old 03-10-2008, 08:52 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Pull out the wet insulation.
Check all areas near that location.
Check the attic as well.
Inspect the back of the exterior wall for rot, mold, damage. If located, treat accordingly.
If it just looks wet, dry it out. If it is really wet: rent a blower.
Once it appears dry - use a moisture meter to check it and the connected areas.
If you have any suspicion that there is mold there, again = treat it.
Once all the interior of the wall and exterior is allset, install new insulation, close up the area.
- Build Well -
Old 03-10-2008, 11:09 AM   #3
The ext. wall is now dry, we don't have an attic, so I would have to take some siding off?
Old 03-10-2008, 11:26 AM   #4
Unless you are seing signs of mold, the siding should be fine. Have you tested the areas for moisture?
- Build Well -
Old 03-10-2008, 12:14 PM   #5
concretemasonry's Avatar
Rewards Points: 2,578
Don't bother to try to dry out fiberglass - just toss it.
It only takes 1/2 to 1% moisture to cut the insulating value in half. I doubt you can afford a moisture meter that is that accurate for something like fiberglass.
If there are any mold spores, you will just be putting them back along with the old insulation. Treatments don't do much to the spores (seeds) but they will kill the active mold.
As Atlantic says, treat any area that you think may have mold. It is cheaper than trying to find out if there is mold, since you cannot really see all of it.
concretemasonry is online now   Reply With Quote
Old 03-10-2008, 03:48 PM   #6
I haven't tested it. Where does the musty smell come from? I threw out the paneling and insulation and after I clean the wood with bleach water I should be ok to put the insulation back up? Along with drywall?
Old 03-10-2008, 03:57 PM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
After you spray the bleach solution, let it dry thoroughly before you put the insulation back in and close things up.
Old 03-10-2008, 04:22 PM   #8
Don't waste your time putting up insulation that was wet. It is just too cheap to use new compared to any problems.
Letting fiberglass dry does not work because it is designed to trap air and stop circulation if it is faced.
Old 03-10-2008, 05:30 PM   #9
Do not use bleach, it is innaffective on pourous surfaces. It will not kill mold spores on wood. Bleach only works on non-porous surfaces (like countertops).
- Build Well -
Old 03-10-2008, 05:32 PM   #10
A home remedy for killing mold (on porous surfaces) involves using a strong mixture of white vinegar. Do your research on the whole subject...
- Build Well -
Old 03-11-2008, 05:46 AM   #11
I was reading up on the subject again and I can't find where I should use vinegar. Can you tell me what site to go to? I would like to do this the right way. I did see that I should not use bleach though.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 09:56 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
