Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-08-2010, 04:59 PM   #1
Wet basement,dirt with cement covered ledges?
My basement has a ledge around it from the floor up about 2 feet.The ledge seems to be cracking and water comming in through it.I pulled a chunk of loose cement off to find dirt under the cement.Was this a way to get a basement to stop leaking years ago? The house is old but the ony place water seems to be comming in is that ledge that looks like it was an afterthought several years after the haouse was built. What is the best way to go about fixing this and sealing up the basement a little better? I was going to get seamless gutters and do some landscaping to run water away from the foundation,but what is a good way to fix up the basement?
bansheex is offline   Reply With Quote
Old 04-09-2010, 10:14 AM   #2
Gutters and proper grading would be the first step. Why not post some photos so we can see the issue?
Ron
gravel tar roof repairing mazizbit Roofing 7 04-09-2012 10:52 AM
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 08:08 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
Why is my living room cement floor covered with black glue? sil Flooring 7 10-29-2007 11:03 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
