Wet Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-09-2008, 07:20 PM   #1
Wet Basement
Hi, I'm new to this chatroom. I have been a homeowner for 10 years and I'm tired of vacuuming the water from my basement after heavy rain storms. My house is 100 years old and the field stone foundation is built on ledge. I have drylocked the walls as has previous owners. My problem is that water is coming in where the foundation wall and floor meet. I have tried hydraulic cement and that has slowed down the amount of water that enters. My basement floor is not level. Should I install French drains? I am pretty handy. Is this something I can do myself?
brianv is offline   Reply With Quote
Old 02-09-2008, 07:54 PM   #2
ICF Construction
Search old threads, this dead horse has been beaten many times.
Real quick, determine if the water is coming from the outside or underslab hydrostatic pressure
Outside, dig it up and fix it right including new weeping tile
Underslab, usually break the perimeter concrete install weeping tile to a sumppit and pump out from there
Chris
Chris Johnson is offline   Reply With Quote
Old 02-09-2008, 08:21 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Also, make sure all drainage (like Gutters and downspouts) are directed away from the foundation. Look into installing a "french drain" system on the interior side of the basement if exterior work does not fix things.
Installing a french drain system is something that an educated (on french drains)..and very handy DIYer may be able to do, and save themselves some money...
- Build Well -
Basement leak dougrus Building & Construction 7 12-31-2007 07:06 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 08:09 AM
