-   General Discussion (http://www.diychatroom.com/f2/)
-   -   Wet Bar Install (http://www.diychatroom.com/f2/wet-bar-install-107047/)
mort5029 06-08-2011 12:39 PM
Wet Bar Install
1 Attachment(s)
I just received delivery on my cabinets for my wet bar. I have never installed them before. They came with two side cabinets and the center one for the sink. My question is, can I just attach all three together first, then slide it against the wall, plum and level it and then screw it to the wall. Finally I will attach the countertop and do sink last . I have seen it done each cabinet at a time but I though this way would be easier considering it's only three. Thanks
12penny 06-08-2011 07:06 PM
hey mort...I dont like doing that way. I shim each cabinet front and back so as to keep it from dropping in the center.
AfterDinner 06-08-2011 08:33 PM
I agree. Especially depending on what the cabinets are made from. Typically they are designed to be attached to the wall. The cheaper the cabinet, the more problems you will have with connecting them together first.
