Were My Rim-joists Sealed Improperly Or Did I Get Ripped Off? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 01:12 PM   #1
Were my rim-joists sealed improperly or did I get ripped off?
I had an Xcel authorized contractor come in and seal the rim-joists in our unfinished basement. They used spray foam from a can to seal the joints and then put new R-30 batt insulation. In some areas they used foam board which they also sealed around with spray foam from a can.
This morning in Denver it's 41 degrees outside.
I am using an infrared thermometer gun to measure the temperature along the base board and right in front of it...the temperature at that spot is averaging 55-57 degrees...two to three feet away from the wall towards the middle of the room the temperature climbs to an average of 64-66 degrees.
The inside thermostat is set to 69 degrees.
Does this sound right or did these guys do a bad job?
Thanks!
Mitch
mitchel is offline   Reply With Quote
Old 02-17-2011, 02:03 PM   #2
This does not sound obviously wrong to me. Insulation is not perfect. Do you know the air temperature in the basement (not sure where your thermostat is)?
oberkc is offline   Reply With Quote
Old 02-17-2011, 03:32 PM   #3
The temperature in the crawl space which is below the rooms that I did the measurments at is 64.6 degrees with 33% humidity.
The worse part of the house is the large crawl space which sits below the bedrooms in our ranch style house (Denver, CO). The contractors are trying there best...they offered to fully condition the crawl space for free. They are going to install some type of thick vinyl on the floor and up the walls and seal everything and then install a vent in the ducting that goes through there...he said that should help a lot.
Old 02-17-2011, 05:01 PM   #4
Rewards Points: 125
I wonder if the issue is not at the rim joists but perhaps in the walls themselves. Gary has posted links and info about convection loops inside of wall insulation.
ThatDaveGuy is offline   Reply With Quote
Old 02-17-2011, 07:12 PM   #5
In my area we insulate the walls with Roxul insulation.
An earthen floor is covered with 6 mil polyplastic sheeting. This vapor barrier is carried up over the wall insulation.
All outside vents are permanently closed off and a hot and cold air supply is provided to condition the crawl space in the same manner as the rest of the house.
Old 02-17-2011, 09:59 PM   #6
Registered User
Rewards Points: 5,516
The rim joist is as cold as the outside temperature, or slightly warmer with the heat from the indoor basement air. Yet it is still cold enough to condense the moisture vapor air going right through the f.g. You need foam board, air sealed at the rim; http://www.buildingscience.com/docum...m-at-rim-joist
Thanks, Dave, copy and paste that link for others, anytime; The "biggest loser" in fiberglass insulation....
Gary
Old 02-18-2011, 07:15 AM   #7
Thanks everyone for the excellent info!
Mitch
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 05:28 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 05:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 06:41 PM
