Weird Things I Find In My Basement - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 02:34 PM   #16
Mold!! Let's kill it!
Rewards Points: 2,012
12 gage wire can be fused for up to 20 amps. I would eliminate the fuses if it is fed from a breaker. Redundant protection isn't necessary.
Old 11-18-2012, 06:54 PM   #17
Rewards Points: 6,034
My first answer would be test to make sure they are still hot, they may have been updated and never removed.
Old 11-21-2012, 01:23 PM   #18
Tileguy
Bud Cline's Avatar
Rewards Points: 558
They were taken with a $30 camera from Ocean State Job Lot. Couldn't find my Nikon.
You can't find your valuable Nikon but you can find your $30 job-lot camera???
What's wrong with that picture?
XXX
Old 11-24-2012, 03:59 PM   #19
Actually, the redundant protection is necessary because Eaton does not manufacture breakers lower than 10 amps,and the necessary protection for the relays on that circuit is 8 amps. There is also a 6 1/4 amp circuit.
neo565 is offline   Reply With Quote
Old 11-28-2012, 08:34 AM   #20
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
The ones I can make out kinda reminds me of my house. I had some funky wiring in my house when I first started tearing into it. I decided to eliminate variables and start with a new panel. From there I just completely rewired all the heavy stuff. Kitchen, air conditioner outlets, bathroom etc. The only stuff that runs on the old wiring now are plugs with lamps plugged into them. I'm not in a rush to change that.
CoconutPete is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Advice on finishing my basement? jakec202 Remodeling 1 07-06-2012 03:11 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Is it normal to find 'strange' things when removing drywall? mikedavid00 Building & Construction 15 03-18-2010 10:49 PM
Rise in basement floor - can't find cause lapwarren Flooring 5 03-05-2009 02:57 PM
