Weedeater Head Stuck - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-17-2013, 09:02 PM   #1
Weedeater head stuck
The knob on my weed eater is stuck it won't unscrew what could be wrong, HELP
DMCM81 is offline   Reply With Quote
Old 06-17-2013, 09:52 PM   #2
Are you sure it screws off? Mine just pulls off.....the part that you wind the string around that is...
Squints is offline   Reply With Quote
Old 06-17-2013, 10:03 PM   #3
Yep I'm screwing it off but it won't unscrew it's stuck I don't want to try to unscrew with the pillars I don't want it to break
Old 06-17-2013, 10:13 PM   #4
Rewards Points: 6,652
They unscrew the opposite direction the head turns.
Old 06-17-2013, 11:43 PM   #5
Rewards Points: 12,856
May be left hand threads.
Never seen one that screws off unless your replacing the whole head and not just replacing the string.
Old 06-18-2013, 07:26 AM   #6
PoleCat's Avatar
Rewards Points: 1,646
There is a bolt in the cap in a channel. If the cap is turning but not getting loose then it is likely the bolt has chewed the channel smooth. If it is that type you will have to replace the cap after you destroy it to get at the bolt.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is online now   Reply With Quote
Old 06-18-2013, 07:54 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
+1 to it being reverse threaded.
Old 06-18-2013, 08:10 AM   #8
Rewards Points: 3,130
My weedeater has a cap that unscrews. It is reverse threaded.
Old 06-18-2013, 08:47 AM   #9
PoleCat's Avatar
Straight shaft vs curved shaft they are opposite rotation. Funny, after around 50 years of being invented there is yet to be a great spool head design.
The Following User Says Thank You to PoleCat For This Useful Post:
gregzoll (06-18-2013)
Shower head dilemma segal Plumbing 2 01-24-2013 12:34 AM
Suggestions for 2 head shower control bodine465 Plumbing 10 11-18-2012 09:53 PM
typical head pressure? gone rayson HVAC 7 10-05-2012 07:41 PM
My shower head leaks when tub faucet is running? Walter Sobchak Plumbing 4 05-24-2010 09:13 AM
outside faucet sprays at head attachment Synthia212 Plumbing 11 03-13-2009 06:53 AM
