Weed Eater/Wacker/Trimmer Cord Replacement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 07:50 PM   #1
I've got a torn pull cord I need to replace on a Poulan Pro 31cc PPB200 gas trimmer. I've been pulling bolts and screws all over the place and the only thing that seems to be stopping me from removing the plastic housing to get to the pulley system where the cord is located, is a silver cylinder rotating cylinder. What next?
ashbroco is offline   Reply With Quote
Old 05-06-2013, 09:35 PM   #2
Rewards Points: 1,294
Here is a page with a exploded diagram that may help you.
danpik is offline   Reply With Quote
Old 05-07-2013, 02:48 PM   #3
You have to buy a new spool of the plastic line. Unplug or turn off the weed eater, and then carefully remove the old spool. Make sure you buy the correct replacement spool.
leenamark1 is offline   Reply With Quote
Old 05-07-2013, 03:48 PM   #4
Rewards Points: 131
If the Poulan is set up like the older Troy Built I have......you're going to need a special socket/key to remove what needs to be removed. When the cord broke on my TB, I did the same as you, pulling everything off. Then with the magic of the intarwebz, I discovered the snag. I saw the tool cost around $80 too......so I begged off.
Chokingdogs is offline   Reply With Quote
Outdoor cord end replacement n0c7 Electrical 3 02-04-2011 11:35 AM
Carpet Install & Phone Cord latheress Flooring 3 01-09-2010 01:19 PM
Ceiling power cord kerry42 Electrical 18 11-03-2009 04:58 PM
Is my extension cord OK? MT Stringer Electrical 4 10-20-2009 08:25 AM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 08:50 PM
