Weatherstripping-door Won't Close - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 12:32 PM   #1
Weatherstripping-door won't close
The Gas Co came out and "weatherized" my home. Now the front door and interior garage door won't close without being slammed. Any suggestions?
Aziegler is offline   Reply With Quote
Old 12-07-2011, 01:09 PM   #2
Rewards Points: 13,270
Call them back and have them redo it.
If they installed metal strips that just have screws in oval shaped holes you may be able to back the screws out a little and pull them back away from the door.
Old 12-07-2011, 01:29 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
I would call them back also as the door shouldn't have to be slammed, but it will be harder to close or the weather stripping won't work well, unless it is magnetic, then there shouldn't be any new resistance.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-07-2011, 03:35 PM   #4
Rewards Points: 5,336
Sounds like they installed a compression weatherstriping on a wood or fiberglass door. While there should be minor pressure involved in closing it, it shouldn't need to be slammed.
They just need to move it back a bit to get the correct position.
Ron
B. Franklin 1759
How to fix uneven gap between door and weatherstripping? Objectivist Carpentry 30 07-11-2015 02:06 PM
How to get double front doors to close tight Advising Elf Windows and Doors 31 12-30-2012 12:09 PM
Replacing weatherstripping on Marvin wood casement windows giger123 Windows and Doors 5 05-09-2011 07:50 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
