Weatherstripping Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-11-2009, 07:10 PM   #1
weatherstripping door
just installed a new front door..the very top of door is not compressing weatherstripping, and you can barely see light. The sides and bottom are good. What kind of weatherstripping could i use on the very top. Its just a plain steel door from home depot..looks like i should have gotten a better brand. I put a piece of foam weatherstripping on it for now, but i dont think it will last long
catmech is offline   Reply With Quote
Old 07-12-2009, 07:19 AM   #2
The door was not correctly installed. You should start over and do it right. It should be plumb/level all around, and hit the weatherstripping evenly all the way around. Rather than nail the door, I use screws, so I can makes adjustments if needed.
Old 07-12-2009, 07:46 AM   #3
it shows to be plumb and level , actually spent alot of time to make sure...also used screws, not sure what the deal is,i have installed doors before, but this is the first time i have ran across this. Its like the factory weatherstripping on the top(knob side) is deformed.
Old 07-12-2009, 12:30 PM   #4
Perhaps you need to adjust the strikeplate on the door a little tighter. Stick a level on the weatherstripping to confirm it is forming a straight line. Maybe it has been shoved back or bent over and simply needs to be lifted out of its crevice.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 07-15-2009, 03:54 PM   #5
It also could be that the door mainframe is out of TRUE. In other words - racked. Just a thought.
fenestrationman is offline   Reply With Quote
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 04:19 PM
Fitting Door Closers clayton1302 Carpentry 6 05-09-2009 09:09 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
