Waterproofing Crack Between Cement And Siding - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 11:14 AM   #1
Rewards Points: 41
Waterproofing crack between cement and siding
I was just wondering if someone had an idea on how to waterproof an exterior area on my house.
My driveway comes directly up to my house and there is a gap between the cement and the siding. Since there is a gap water is getting in there and potentially is starting to rot the wood. I needed something to fill in that gap.....any ideas?
I can probably think of a few things but I'd like to do it properly if there instead of being the diy'er that ghetto rigs his house.
As you can see also I need to make some repairs on the door frame.
Thanks in advance!
01grander is offline   Reply With Quote
Old 02-20-2013, 11:14 AM   #2
kwikfishron's Avatar
Rewards Points: 180
What you should do is cut off the lower 6" or so of the wall and pour a concrete stem wall to get the framing is above grade.
Short of that would be to cut a groove in the concrete and install a Z flashing that's bent slightly under 90 deg. that goes behind the siding and weather barrier and up the wall at least 3".
kwikfishron is online now   Reply With Quote
certainteed cement siding cracking! wichitawings Building & Construction 23 11-04-2010 07:55 PM
hardie plank siding bob fortier Carpentry 4 05-31-2010 08:01 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Is this Asbestos Siding or Cement Siding? Pictures inside!!!! twilightcall Remodeling 12 02-01-2008 08:27 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
