Waterproofing Basement Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-29-2009, 12:11 PM   #1
waterproofing basement question
We're thinking of hiring a guy (I think he'll use a backhoe) to come dig down below the footings, tile, rubber coat the walls, pea gravel etc. to stop water from getting in. Our house is pretty small and square (apprx. 1200sq ft.) Does anyone have a vague idea of what a project like this may cost? $5,000, $10,000???? Thanks!!!
annie68164 is offline   Reply With Quote
Old 04-30-2009, 06:17 AM   #2
A properly done drain field around the foundation perimeter is the best way to keep a basement dry. That is best done when the house is being built, and can be expensive after the fact. Prices can vary widely depending on what is actually done, and your area.
Basically, you should have a drain pipe(w/holes) at the footing level, surrounded by a free draining fill(pea gravel), wrapped in landscaping cloth to prevent the system from silting up. The walls will be covered with a water proof membrane(quite a few possibilities), and the there will be a membrane about 1 ft below the top of the grade level, which slopes away from the house with the grade.
Basement flooring question kelot Flooring 2 10-23-2008 04:06 PM
Basement door question number6 General DIY Discussions 7 07-17-2007 02:54 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-22-2006 11:03 PM
