Water Seepage Into Basement "help" - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-06-2009, 04:39 AM   #1
Question
water seepage into basement "help"
I am an landlord and in the basement unit there is water spots on the carpet near the foundation walls in one room. The house is 30 years old and never had any problems before! I have own the duplex for 5 years and never seen any water problems. It is spring time and there is a lot of water in the ground and it is raining out. There is no water on top of the grass. There is no sump in the house. What should I do ? Is there any tempulary fixes I can do until the ground thaws out.
VLT4444 is offline   Reply With Quote
Old 04-06-2009, 05:22 AM   #2
Remodeling Contractor
Pull up the carpet. Seal the concrete floor with concrete sealer. Cover with 6 mil poly, replace carpeting. Paint the walls with two coats of Dry-Loc. This is a minimum step. you best to put in a perimeter drain and be assured of no water damage in the future.
Help With Basement Flooding !!!! gottabee Building & Construction 45 01-19-2009 05:42 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water in Basement of New Build earthmom Building & Construction 2 01-04-2008 12:51 PM
basement floor water bigboyjoel Building & Construction 1 05-21-2007 04:46 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
