Water Seepage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 11:26 PM   #1
Water seepage
My home has a ground level 'basement' and has just had seepage. My parkay tiles are wet. How much of a foundation would my home have? Any comments?
chefmitch is offline   Reply With Quote
Old 03-13-2011, 12:17 AM   #2
Registered User
Rewards Points: 5,492
Welcome to the forum!
Are the walls concrete? Are they below grade anywhere? Are the downspouts 5' from the house? Is the earth pitched away from the house? Do you have a sump pump or exterior drainage system?Are the walls below grade damp-proofed? Need more info....
Gary
Old 03-13-2011, 01:22 AM   #3
Wink
Info
Hello Gary,
This is my first home and only moved in Oct last year, so forgive me here.
Downspout is not 5' from house
Ext walls are brick
The home was built in 1980 in Canada
Prob slab on grade? Townhouse
I dont know how far down footings are
We have had alot of meltwater that seems to have washed earth out from under the pavers in backyard...therefore there was some gathering of water at the foundation.
Question is will I need to dig only the affected stretch of foundation to seal, and bakfill or just add material to slope. From house?
Also if it is slab on grade or the like, do I need a weeping system?
Cheers for the help!
Old 03-15-2011, 07:27 AM   #4
You need to get the water away from the house. Find the source of the water, downspouts, where your sump pump drains to, ground water etc. I like weeping tile to take ground water and proper grade with grass to remove surface water.
screwy is offline   Reply With Quote
Old 03-15-2011, 03:27 PM   #5
Licensed Pro
kcremodeling's Avatar
Yea. I would def check the grade, gutters, and install a french drain in necessary.
kcremodeling is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
