Water In The Room After Heavy Rain - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 06:00 PM   #1
water in the room after heavy rain
After heavy rain in Texas , we noticed small puddle of water in our walking closet. The closet is at the front end of the house with an exterior wall .There are roof drains outside that wall , The adjacent rooms & upstair rooms are dry. The drywall is also dry.The closet is tiled & the water is concentrated on one side only . I also noticed that the caluking between tiles near the wall on that particular are is not done correctly.
The closet is about 200 sq ft wwith all other areas bone dry. we have been living here for past 5 years. This is the heaviest rain we ever had after a drought in all these years. What might be the cause ? what should I do ?
thanks in advance
mom1967 is offline   Reply With Quote
Old 01-25-2012, 06:52 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,346
Ayuh,.... Scared dog, or child maybe,..??
The water had to come from Somewhere,.... Look for it's trail....
Through the wall,..??
Old 01-25-2012, 07:27 PM   #3
No dog or small child.
The only issue I can think of clogged gutters outside the wall., water was gushing over the gutters last night.Our roads were flooded due to heavy rain.
There is also a small area between tiles not grouted or sealed properly. This was really puzzling since everywhere else is dry .the walls are dry as well.
Old 01-25-2012, 07:41 PM   #4
I would not worry about the caulk inside. The water is coming in from outside. Pix of outside would help. Clean gutters, make sure water is discharged away from the house, 3" of rain on a roof will be a lot of run off.
Hardway is offline   Reply With Quote
Old 01-26-2012, 12:29 AM   #5
Retired carpenter
Is your floor on a concrete pad, or wood with a crawlspace/basement? If it is on concrete, water might have seeped from underneath through the path of least resistance (the defect in the tile installation).
abracaboom is offline   Reply With Quote
Old 01-26-2012, 05:49 AM   #6
It is on a concrete pad. We do not have a crawl space or basement. The previous owner tiled the room herself.
other than cleaning the gutters , what can I do to improve drainge ? -( Change the size of downspouts or put french drains in that area) ?
We had 5-6 inches of rain within 24 hours - a rarity in this part of Texas.
Old 01-26-2012, 06:29 AM   #7
Rewards Points: 1,512
The first thing to check for and fix is water pooling up against the house.
This may require regrading of the land.
Old 01-26-2012, 06:39 AM   #8
I am new to all these - ( the questions may sound stupid & apologize for that ) . whom should we call to regrade the land ?
Old 01-26-2012, 07:08 AM   #9
The "best" move would be to consult a landscape architect, and have them plan it out for you, but that's likely to be expensive. You could ask around for recommendations for someone who does site work. A quality landscape operation should be able to do it,......or someone who installs septic systems..
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 01-26-2012, 08:07 AM   #10
Rewards Points: 13,694
Post a picture of the outside of the house and it should be simple to see what's wrong.
Old 01-26-2012, 03:07 PM   #11
Retired carpenter
Whom should we call to regrade the land ?
A guy with a shovel.
Some guy who does yardwork by the hour.
If the water came from underneath, that means there was water under pressure underneath the concrete pad, which can only be fixed with a French drain (installed by a guy with a shovel and good directions).
I would start by digging a small hole (shovel width, 3 foot deep) right next to the house by that closet. If it fills up with water, you've found the culprit.
Old 01-26-2012, 03:21 PM   #12
post hole digger, perk 3 holes.
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
