Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-02-2010, 07:41 PM   #1
water problem
Water flows nonstop into my sump pump 24hours a day every day. I've burned out several pumps. Where is this water coming from?
reenmt is offline   Reply With Quote
Old 08-02-2010, 07:52 PM   #2
Moderator
water problem
Have you turned off your house water supply at the property entrance and watched the meter numbers change over a time period?
Be safe, Gary
Clothes taking longer to dry?
Old 08-02-2010, 08:39 PM   #3
water problem
Water Storage may be overflowing. Trace the water origin.
MagicalHome is offline   Reply With Quote
Old 08-02-2010, 09:30 PM   #4
water problem
Your house may be built on a swamp or else on a spring!
Usually a good pump will last for years, ever if running continuously.
Stopping and starting is harder on a motor than continuous running.
If the pump bearings are run continuously, they may sieze up and burn out the motor.
Perhaps a pump with a greater rate of flow would be a good idea. It would quickly draw down the water level and allow parts to cool. That, or install two pumps!
Hot water problem ges145 Plumbing 3 07-05-2009 06:32 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
hot water recirculating/sediment confusing problem rcatty Plumbing 1 01-06-2008 04:51 PM
water pressure problem rgmetro Plumbing 6 04-09-2007 04:57 PM
Water Delivery Problem amadis Appliances 6 12-20-2006 11:22 PM
