Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-19-2006, 01:08 PM   #1
Question
Water leaking over fireplace
We have a wood-burning fireplace insert with vinyl siding covering the chimney above the roof. During a recent rainstorm, we heard water dripping (loudly) onto the metal box inside the fireplace box (but not into the actual fireplace). A few minutes later, water started running in streams over the top of the fireplace, between the sheetrock and the actual fireplace. We had the installer come and take a look, but today it happened again, the first rain after it was repaired. I don't think it's the roof flashing b/c it's not running down the wall (no sheetrock damage), but I can't get a straight answer. Any ideas?
mmcginn2 is offline   Reply With Quote
Old 04-21-2006, 12:42 AM   #2
Darylh's Avatar
Sounds like the rain is finding its way down right beside the chimeny pipe itself so I would look for cracks or openings beside the chimeny pipe. Is it a metal or clay flues?
Darylh is offline   Reply With Quote
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 05:50 PM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 07:22 PM
leaking water main LanterDan Plumbing 4 08-31-2006 08:24 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Fireplace leaking mmcginn2 Roofing 4 04-23-2006 11:12 AM
