Water Heater Pilot Light Going Out - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 07:17 PM   #1
Water heater pilot light going out
I have a GE water heater made in 2005. Pilot light will light, but within a day it will be out again. Is the thermocouple bad? Venting seems good
jbjones is offline   Reply With Quote
Old 04-10-2011, 07:33 PM   #2
It's possible that the thermocouple is slowly failing, but all of the ones I have replaced in my HWT have failed completely and then would not stay relit. Maybe a loose connection? The 5 year time line sounds about right for the life expectancy I have had. They are pretty cheap and easy to replace so it may be worth a try.
If it gets really windy here it will blow ours out occasionally. How has your weather been?
SM
MarshSt is offline   Reply With Quote
Old 04-10-2011, 07:48 PM   #3
It's been windy, but that has never been a problem before. This has happened 3 days in a row now. If it goes out again, i guess I'll try replacing thermocouple. Do I have to replace the gasket on the cover. Can I get both at any hardware store
Old 04-10-2011, 11:43 PM   #4
A Little Of Everything
Rewards Points: 1,364
Just replace the thermo-coupler. Most kits are only about $10. Even if that's not the problem, you're not out much.
But... I'd bet that IS your problem.
DrHicks is offline   Reply With Quote
Old 04-11-2011, 12:16 AM   #5
Rewards Points: 1,016
Yup, I would try the thermocouple first, then go from there if need be.
Gas water heater - after long use pilot goes out. paulsaindon Plumbing 1 07-14-2011 05:51 PM
Water heater won't light adfuhrer HVAC 1 12-10-2010 03:59 PM
Water heater won't light adfuhrer Plumbing 0 12-10-2010 03:11 PM
Problems with water heater jwise Plumbing 11 02-26-2010 08:36 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
