Water Heater - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-30-2007, 02:10 PM   #1
water heater
My water heater sit in my garage 18 inchs off the ground.I recently have put drywall on all wall and ceiling.I would like to enclose my washer and dryer,but my concern is can i box and enclose my water heater and only leave vents .
ATEAM is offline   Reply With Quote
Old 10-30-2007, 10:46 PM   #2
remodeling pro
A general answer "yes", but I would check with the local plumbing/mechanical inspector on it. There are lots of quirks in local plumbing codes, and you may be required to install a supply of "makeup" air if it is a gas fired unit. If it is electric, you can just about do anything.
troubleseeker is offline   Reply With Quote
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
