Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-30-2011, 01:33 PM   #1
water in garage?
My garage is about 50+ years old, it is detached from the house. The inside has no insulation or drywall, the celing is open to the rafters and ceiling joists as well. The problem I have is when it rains hard for a long time, water actually comes up though the concrete, not puddling, but the whole slab becomes moist to the touch. And I do have adequate drainage, the land slopes away from the garage on all 4 sides and the gutters are piped out to the street.
Now I have thought about doing some kind of sealer on the concrete so this does not happen so I am not sure if this is a good fix or not.
Also becasue of this I have a serious problem with condensation, I use the garage as a work shop and I am noticing my tools are becoming rusty very fast, I am sure this is because the moisture can not escape once it comes though the slab. Now my roof does not have any venting at all, would adding a few of those cheap plastic roof vents help this problem? If so how many do I add? The garage is 10'x24' and with a 8' plate height and again the rafters are open there is no drywall on the ceiling or walls.
I dont want to put to much money into this garage because in a couple years I am planning on tearing it down and rebuilding a larger garage, but I would like to try to help the problems I am having now until I get to that point.
Thanks!
cbzdel is offline   Reply With Quote
Old 03-31-2011, 07:18 AM   #2
water in garage?
Sounds like you have done everything to get surface water away from the footers/slab. I will have to guess you have a high water table, and there is no solution for that. It is rare to see a sump pump in a garage, but that might be what is needed.
Old 03-31-2011, 07:44 AM   #3
water in garage?
if its an older garage, there's probably no vapor barrier under it,,, there are siloxane sealers that will work - even at the apron stores
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 03-31-2011, 04:33 PM   #4
water in garage?
I agree with the no vapor barrier as said above. If I put down a sealer would that cause problem, might sound stupid but it seems like it could cause problems if the pressure really builds up.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
water pooling around garage door ljr General Discussion 4 03-01-2011 01:46 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Water running from Driveway into Garage. CAD Building & Construction 5 06-17-2010 08:30 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
