Water In Floor Air Vents - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-06-2013, 02:44 PM   #1
water in floor air vents
I live in a mobile home and I am finding water in my floor air vents in the living room and kitchen. Can you give my an idea of what kind of problem that I may be facing and do I need to call a professional asap????
frustrated22 is offline   Reply With Quote
Old 08-06-2013, 02:59 PM   #2
Rewards Points: 14,290
Locating the source is #1.
If you have central A/C I be making sure the condensate line is not plugged up that runs from the pan under the slant coil inside the inside air exchanger.
100% sure someone did not just get to aggressive with the water when washing the floors?
Condensation from uninsulated lines?
Where there's moisture there's going to be mold growing.
Old 08-06-2013, 03:00 PM   #3
Rewards Points: 274
So sad that you are facing a severe problem, try to mop so that it can be dry or it is better to call some professionals as they have proper system/team to make it dry and clean out all.
alexjoe is offline   Reply With Quote
Old 08-06-2013, 03:11 PM   #4
Rewards Points: 6,652
Sounds like someone poured water into the vent in the Kitchen. Usually with Mobile homes, you have one long trunk that serves all vents along that run, at the top on the floor.
Worse design a hvac engineer came up with, is flush mounted floor vents. Especially in baths, Kitchens and Laundry areas.
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Water in Floor Vents dfedele84 General DIY Discussions 3 05-10-2007 07:24 PM
