Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-21-2012, 08:17 AM   #1
Water feed valve
As wondering if by chance there is a way/ device that can detect if there is a leak in the hot water tank. I ask because my basement is newly finished and I can only imagine coming home to find the bottom blew outta the tank and filled my room with 60L of water... But is there a way that this is the only water that will leak... Not keep flowing out the main?
stoked91 is offline   Reply With Quote
Old 02-21-2012, 08:23 AM   #2
Water feed valve
If the bottom rust out or there's an over tempature and the relief valve pops off as long as the supply line is open waters going to keep coming out, not just the 60 gal.
The tank should have been installed sitting in a pan with a drain on it.
There is sensors you can by that can be sat in the pan and when it sinces water it shuts the main off with an electric solinoid.
Old 02-21-2012, 08:31 AM   #3
Water feed valve
I have heard of that... But where can I find something like that?... I was planning on building/ forming a small dyke wall around my water tank so if it leaks it will mostly be contained... Then like you said... I need the electrical shutoff!
Old 02-21-2012, 08:34 AM   #4
Water feed valve
Not going to do any good to form a dam.
Just Google "auto water shut off valve" dozens show up.
Your going to need a 3/4" valve.
It goes on the inlet side.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
hot water check valve? KE2KB Plumbing 7 01-30-2009 02:36 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
