Water Entering Basement From Under Bulkhead Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 03:27 PM   #1
Hello everyone, we purchased a new construction home 10 months ago and from day 1 we have been getting water in our basement which enters from the bulkhead door. Builder sent someone by a few months ago to reseal, but that has not fixed the issue. I'm not sure the extent of the issue and if/when I should threaten legal action against the builder. Here are some pics:
Any guidance is greatly appreciated.
heywood450 is offline   Reply With Quote
Old 08-07-2011, 03:52 PM   #2
Rewards Points: 6,652
Really need to see what it looks like on the other side.
Old 08-07-2011, 06:15 PM   #3
Here are some more pics to get perspective on the issue. Appreciate any responses.
Water Entering Basement From Under Bulkhead Door-8-7-11-2.jpg   Water Entering Basement From Under Bulkhead Door-8-7-11-3.jpg   Water Entering Basement From Under Bulkhead Door-8-7-11-4.jpg   Water Entering Basement From Under Bulkhead Door-8-7-11-5.jpg
Old 08-07-2011, 06:55 PM   #4
No drainage and the fact that the door is allowing water to just come on in is the problem. There should be a weeping drain in the floor of the entry, or at least a trough, so that water can not be allowed to enter the basement. Get the contractor to fix. It does not cost anything to have your warranty contract reviewed with a lawyer, but it will cost you to bring in an engineer to give you suggestions. Do not let them just band-aid the problem, have them fix it right the first time.
Old 08-07-2011, 11:05 PM   #5
Work Hard, Play Harder
Rewards Points: 212
As greg mentioned, there should be a drain leading into your weeping system/sump pit.
We had this problem with our home (100 years old though); had to have a trough drain run across the doorway going into interior drain tile / sump pit.
It will be worse in the spring.
coderguy is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Not another basement water "management" thread! mwpiper Building & Construction 11 02-06-2012 07:31 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
