Water Coming In Under Basement Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 05:18 PM   #1
Water coming in under basement door
Hello all, just joined, and looking for an answer to this ongoing problem. Bought this house just over a year ago and until now I've just accepted the water coming in my basement during bad storms, but I'm looking for something to prevent it.
I have a concrete stairway leading to a basement entrance, it is about 5-6 steps. At the bottom of the steps is a drain, which leads to a secondary sump pump. The sump pump works great and drains efficiently. Unfortunately, the smallest amount of dirt, leaves, etc. that builds up over the drain prevents any water from going down the drain. Now I can keep the area as clean as a whistle but with the heavy rain storms in Chicago lately, it just drags new garbage into the stairway, over the drain. And if I'm not home to constantly check to make sure its clear, the water will come pouring in.
I had a drain plate with about 5 holes and replaced it with one with 30+ holes, but same result. This may or may not effect your thoughts but there is a small deck above it so you can walk out the kitchen door to the outside. Walking in and out of the basement steps, you must duck slightly not to hit your head. So any suggestions are welcome. Thanks for your help!
lucaduc is offline   Reply With Quote
Old 07-28-2011, 06:05 PM   #2
DIY staff
Rewards Points: 7,174
You are going to have to replace the drain with a trench drain----
or find a large grate that you could place over the landing so water only ,but no debris can reach the existing drain.
Old 07-28-2011, 06:50 PM   #3
thanks for the response...my first idea was a grate-type application and it looks like the trench drain is the same concept i was thinking of...any chance you can provide a link to one that is suitable for a small area...the ones i'm finding are 4 foot wide and would take a hell of a lot of extra work than i'm capable of....im thinking of something ~1 foot wide (maybe even a square 1x1 grate)
Old 07-28-2011, 07:48 PM   #4
DIY staff
I don't know where you are located----See if you have a concrete supply company locally.
A plumbing supply house could also get that drain for you. a 12"x 12" would do nicely.
It sounds like an interior drain was used---Might be one of the plumbers here will chime in--Mike---
Water coming up through cracks in basement rockarmygreen Flooring 11 04-09-2015 10:26 AM
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 09:34 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
