Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-25-2008, 09:01 AM   #1
Water coming in the house and a leak
The sidings of my house was replaced by hardiplank. We had a big storm this week and noticed one side of the house, water are coming in the house by almost all the windows, and there is a leak on the 2nd floor of the room.
This never happened to the house were I've been living for 17 years?
Is it something to do on how the hardiplank was intalled?
Please advise./
Thanks,
laarni is offline   Reply With Quote
Old 07-25-2008, 09:14 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
I would have to say yes, I didn't happen before, Please take a few pictures of the troubled area and with the contractors on the site we will be able to guide you in the right direction, BOB
Old 07-25-2008, 09:26 AM   #3
I will do that and send it to you.
Old 07-25-2008, 09:45 AM   #4
Moderator
Termite's Avatar
Yes, if it happened at more than one window, there's a high probablility that it has something to do with the new siding job. You should not try to make the repairs yourself, and should hold the contractor that did the work liable for the water infiltration.
Old 07-26-2008, 02:08 AM   #5
naturelimit is offline   Reply With Quote
Old 07-26-2008, 07:19 AM   #6
ccarlisle's Avatar
Unhappy
It's a bit tricky getting the new siding to cover the gaps around windows and doors properly. First, he must insulate the gap with foam, then caulk. It has to be a very good fit for there not to be leaking of some kind but some know the proper caulk to use.
ccarlisle is online now   Reply With Quote
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 10:24 PM
Info/advice needed for basement leak 60 Yr old House pkovo General Discussion 6 01-15-2009 11:40 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Possible Fireplace/Chimeny Leak? CharlesMTF Building & Construction 4 10-16-2005 05:49 PM
