Water In Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-09-2008, 11:22 PM   #1
Water in Basement
I have a problem, its been a day since the rain stopped still water is pouring into
sump pump **** any help
baki is offline   Reply With Quote
Old 06-10-2008, 08:40 AM   #2
Registered User
Termite's Avatar
If the water is filling the sump pit and the pump is properly discharging the water, that means that your system is working correctly. If it weren't, you'd have water in your basement.
Water in the soil surrounding your home can take days to leech out, depending on the soil and subgrade conditions.
Be sure that your sump pump's discharge pipe discharges a good distance (hopefully downhill) from your house. If it discharges close, you're just pumping the same water over and over.
Stumped: Basement water and fix- Did I make things worse? jws3 Building & Construction 27 10-16-2008 08:38 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
Water in the basement - help! jkrodger Building & Construction 6 03-19-2008 04:25 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
