Washing Machine Capacity Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 07:14 PM   #1
Washing machine capacity question
I've been using a small laundromat that has Maytag commercial washing machines. I looked them up and found that the capacity is only 2.5 Cu. Ft. That seems very small, I guess they want you to do multiple loads so you keep feeding the quarters into the machine.
Anyway, I will be buying a front load machine with a 4.2 Cu. Ft. capacity. Can I realistically put almost twice as much clothing in as I did with the 2.5 Cu. Ft. unit? Are the Cu. Ft. ratings real world numbers that I can judge the load size off of? Thanks!
General is offline   Reply With Quote
Old 12-12-2010, 09:07 AM   #2
Rewards Points: 5,336
The drum of a washing machine is essentially a cylinder. If you want a real world understanding, take a tape measure and measure the diameter and the depth of the drum.
volume(of a cylinder)= 3.14(Pi)*radius squared(1/2 the diameter)* depth(of the cylinder.
See how that compares to the stated volume.
Ron
Old 12-12-2010, 09:43 AM   #3
Ron
I guess I didn't explain it correctly. What I am basically wondering is if the CU FT capacity of a washer doubles, can I realistically double the amount of clothes that I put into it?
I know this seems like a no-brainer type question, but I just want to be sure. Also, I'm not sure how CU FT translates between load sizes when comparing top load to front load machines.
Old 12-12-2010, 10:54 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,706
Ayuh,... With my ole washer I can load 10 pairs of jeans, 'n it'll run just fine...
If I only put 4 or 5 pairs in it, they come out cleaner...
You'll have to be yer own judge...
Old 12-12-2010, 11:01 AM   #5
What is Ayuh?
What I am asking is this: I can put 5 pairs of jeans in the machine I currently use (2.5 CU FT). Can I put 9 pairs into a 4.2 CU FT machine and have them come out just as clean?
Old 12-12-2010, 03:31 PM   #6
Originally Posted by General View Post
What is Ayuh?
Not quite as clean, but you'll never really know, will you.
Ron
Old 12-12-2010, 04:47 PM   #7
Not quite as clean
OK, so that would mean cubic footage isn't a determining factor in how much clothing can be put in a washer?
Old 12-12-2010, 06:00 PM   #8
Bondo's Avatar
Ayuh,... 'course it does, but it depends on how Hard ya pack 'em in it...
Old 12-12-2010, 06:23 PM   #9
Wow....
If you packed them both the same...?
Ayuh Ayuh.
Drain hose stuck on washing machine savingedmund Plumbing 3 05-10-2009 10:19 AM
Quik Question about Washing Machine evol200 Appliances 2 01-01-2009 11:25 PM
Washing Machine Drain mqcarpenter Plumbing 3 11-20-2008 07:47 PM
Washing machine lint filter Dragonladie Plumbing 4 10-19-2008 06:52 PM
Reclocate Washing Machine , drain question ekimak0930 Plumbing 2 09-14-2008 07:29 AM
