Want To Build Corner Shelf For 27" Tv In Garage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-07-2009, 02:52 PM   #1
Rewards Points: 77
want to build corner shelf for 27" tv in garage
Any plans or pics I want to build a corner shelf to get my tv off of the groung in the garage. It si quite heavy as it is an old school 27" any help would be appreciated. Thanks.
bowanna03 is offline   Reply With Quote
Old 07-08-2009, 05:57 AM   #2
A piece of plywood would work for the shelf, the secret is bracing it properly. I would but one brace at the back corner, and two toward the front sides. It will have to be wide enough that you can hit studs with all brackets. If the plywood is thick enough, just run 2x4 under the shelf across both walls.
Old 07-08-2009, 06:09 AM   #3
Rewards Points: 77
Good deal I will try it out.
Hanging shelf (mini "loft") from finished garage ceiling bdr Carpentry 6 11-30-2008 10:31 PM
Storage shelf above garage door BigMonkey Building & Construction 5 08-25-2008 12:05 PM
Adding on to house to build a garage. Ohioguy Building & Construction 5 02-09-2008 04:44 AM
Frost Build Up On Interior Garage Wall richw Building & Construction 8 01-06-2008 09:47 AM
