Wall Shear Strength - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 05:44 PM   #1
Wall Shear Strength
So I opened up a wall and discovered 1x6's nailed to it all over. Possibly used as an old form of sheathing back when the house was built. I think this was an old exterior wall that eventually became an interior wall. I need to remove the strips to insulate, add electrical, make the new wall line up with the door jamb, etc. Is there anything I should worry about as far as the wall's shear strength? I know that sheathing can also serve a structural purpose. Is there any way to brace it flush somehow without protruding from the front? This is for a small foyer room which opens up to two separate doors for a duplex.
Here's pics of what I'm talking about:
http://i746.photobucket.com/albums/x...b/DSC00116.jpg
http://i746.photobucket.com/albums/x...b/DSC00118.jpg
http://i746.photobucket.com/albums/x...b/DSC00117.jpg
Thanks!
Greg
c00rdb is offline   Reply With Quote
Old 07-23-2010, 05:59 AM   #2
Yes, that is how sheathing was done back then(before plywood), and it can probably be removed without any structural issues. I would not remove the whole wall, however, without a professional look-see.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 10:30 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
