Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-25-2013, 06:36 AM   #1
wall screws / hangers
My walls in my flat are basically plyboard and plaster, my little girl could properly punch a hole in them, however what's the best way and equipment to use for hanging large items like mirrors and cupboards, normally I would drill a hole put in a walplug then screw, but with thin walls or walls that like to break apart I need some new and better ways, thank you
falconsirrus is offline   Reply With Quote
Old 01-25-2013, 12:35 PM   #2
Never heard the terms "plyboard" or "wallplugs", and I don't think I'm the only one! Anyway, cupboards are usually fastened to the studding, or to cleats that are
in turn fastened to the studs. There is quite a variety of devices designed to mount medium-weight objects to hollow walls, any decent hardware store
will carry a variety of them.
kreemoweet is offline   Reply With Quote
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
Wall Cabinet - How many screws cfreak Carpentry 6 12-21-2010 12:46 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
