Wall-nuts - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 11:53 AM   #1
Unhappy
wall-nuts
I'm wanting to install soap insets in my 36x36 shower.
I will also be installing a glass door.
I don't have a clue where to go with these projects.
wall-nuts is offline   Reply With Quote
Old 09-20-2010, 12:23 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
nuts, Welcome to the Forum
Surface mounts are much easier to install than insets. Some even come with Suction cups for instant mounting.
http://www.thefind.com/furniture/info-teak-shower-shelf
Corner shelves as in the attached pic can be glued on
Shower doors as far as I know are all a custom install because of the huge range in sizes and types of glass. They also have to be tempered glass so it is not usually a DIY project.
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
wall-nuts (09-20-2010)
Old 09-20-2010, 01:39 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
While I have done quite a bit of tile work, I am by no means an expert like some of the fellows here on the board. What I personally would do if I wanted to do that is cut the holes with a side grinder with a diamond blade. Cut all the way into the cavity of the wall, wad up some newspaper and stuff into the hole. mix up some plaster of paris and put a glob of the plaster on the back of the soap dish and insert it into the hole you cut. You may have to secure the soap dish until the plaster sets up. That is what I would do. There may be newer ways to do it now days but hey, I am an ole man, ya know.
Hey Bob, I love that shower, that is nice.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-20-2010, 01:40 PM   #4
Rewards Points: 24
In regard to "soap inserts", is your shower tile? If so, are they large tiles, as shown in Bob's picture? If so, I agree. If they are smaller tiles, I would remove a tile (or tiles), depending on the sizes of the tiles and soap inserts, and grout it in place.
In regard to installing a glass door, my suggestion would be to get the exact dimensions that you will require, then check with you local lumber yard or building center. Although this is obviously an abbreviated version, a typical first time installation will involve drilling some holes in your side walls, screwing the side panels in place, assembling, and caulking. The only thing that I have successfully done differently on reinstallations, if the hinge panels are predrilled, is to drill new holes in it, which align with the holes in the wall, and then plug the original holes in the panels with plastic caps and a dab of caulk. This is not necessary, but it eliminates the need to drill additional holes in the tile. Regardless, your local supplier should be able to provide you with an installation manual, or at least point you to a website where you can download one, to see if it is something that you want to take on yourself.
The Following User Says Thank You to DexterII For This Useful Post:
wall-nuts (09-27-2010)
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 11:30 AM
building a wall against an exterior wall Mike L General DIY Discussions 2 08-20-2009 03:50 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
