Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-30-2008, 08:08 PM   #1
wall mounted flip up desk
I am home improvement challenged. I would like to try to create two desk areas that can be wall mounted and lay flat against the wall when not in use. Can anyone help me with how I need to plan this out and what I need to mount the work surfaces and what I need to keep them them up and sturdy when in use?
Thanks!!
chickadee is offline   Reply With Quote
Old 09-30-2008, 09:22 PM   #2
You can find special collapsing brackets at Rockler or one of the other online woodworking companies. I used them when I built a drafting table. Mine was about 30" deep by 36" wide. I used 3/4" oak plywood for the table.
Ron
Old 10-02-2008, 05:40 PM   #3
Hi,
Do a Google search on "gate leg table".
Just use part of one.
You can build it yourself and in no time you'll be DIY proficient.
Cheers
Bill.
billbeee is offline   Reply With Quote
Old 04-01-2011, 03:27 AM   #4
Search for every single material that you need to use, before doing what you want for you to produce not a only a good desk but specially a quality desk.
desiree_furman is offline   Reply With Quote
Old 04-01-2011, 11:08 AM   #5
Make sure your desk has (folding) legs of some sort to support the weight.
pyper is offline   Reply With Quote
Old 04-04-2011, 10:05 PM   #6
i agree with that pyper, for safety purposes just in case.
Old flip top school desk Zarack Carpentry 15 09-09-2008 10:57 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Wall mounted scart / aerial socket miked Electrical 5 01-05-2007 06:40 PM
