Wall Mount TV Near Chimney? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-27-2008, 10:07 PM   #1
Would like to wall mount an LCD TV on the wall above a fireplace mantel. Do I have a problem running wires between inside of drywall and chimney?
Ernie
erniedev1 is offline   Reply With Quote
Old 10-28-2008, 05:20 AM   #2
Rewards Points: 5,336
You will not run any wires in the chimney. If you have a chase behind the drywall, you can use that to run the wires.
Ron
Wall mount toilet warnerww Plumbing 3 07-04-2011 09:01 PM
Bracket to Ceiling mount a Wall mount floodlight Ski Electrical 1 06-27-2008 12:18 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Moisture-proofing chimney box wall penetration faithmyeyes Roofing/Siding 3 01-06-2007 12:23 AM
