Wall Insulation - Batt Vs. Blown In - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 08:31 PM   #1
Wall Insulation - Batt vs. Blown In
Which is better to use batt insulation in a wall vs. blowing insulation in?
I have 2 exterior walls, 1 wall plaster is removed and when closing back up the walls I'll be installing batt.
On the 2nd wall, the plaster is still up and I'm debating adding a day to my project to rip it out and install batt on that wall too.
Thoughts?
Thanks!
mykquin is offline   Reply With Quote
Old 11-07-2011, 08:42 PM   #2
Rewards Points: 6,652
Compacted blown would be the best route. Placing batts in the open walls, will just allow air movement. You really need to read the info at the Building Science website.
Old 11-07-2011, 10:29 PM   #3
Rewards Points: 1,092
Dense-packed, either cellulose or fiberglass, is far better. Figerglass batts are the worst insulation made, unless perfectly installed (a rarity) and then it is still not great. It's OK, tho.
Old 11-07-2011, 11:22 PM   #4
Registered User
Rewards Points: 5,194
Will you be caulking the stud/sheathing/plates joints before insulating?
Will you be air-sealing the drywall (ADA-- airtight drywall approach)?
Do you have any rigid foam board on the exterior?
Where are you located?
Gary
Gary in WA is online now   Reply With Quote
Old 11-08-2011, 04:25 PM   #5
The studs/sheathing/plates are already up/in
don't know what air-sealing is...should i do this?
standard (1/2" or something) sheething then brick exterior
Live in PA
Gary
Really appreciate the insight...
Old 11-09-2011, 01:55 PM   #6
check out Air Crete..
http://airkrete.com/index.php
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 11-11-2011, 08:27 PM   #7
Gary
I'm leaning towards blown in fiberglass insulation...any additional input?
Old 11-11-2011, 08:39 PM   #8
Registered User
You should caulk the studs/plates/sheathing to prevent air leaks: pp.21: http://www.engr.psu.edu/phrc/trainin...ngbarriers.pdf
ADA: http://www.buildingscience.com/docum...wall-approach/
Problem with sheathing on a brick wall and air-permeable insulation: http://www.greenbuildingadvisor.com/...moisture-walls
http://www.buildingscience.com/docum...n-brick-veneer
I'd use cellulose or ? other than f.g: http://www.nrc-cnrc.gc.ca/eng/ibp/ir...ling-heat.html
What are the odds, I was typing when you asked.... Lol.
Gary
Tags
batt insulation , blown insulation , insualtion
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 03:50 AM
Basement XPS and Batt insulation? BlueBSH Building & Construction 5 01-17-2010 08:57 AM
Exterior Wall Insulation require plastic barrier? BillyDIY Building & Construction 14 03-05-2009 11:19 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
