Wall Has No Gaps Between 2x6s "studs"!! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 01:52 AM   #1
Wall has no gaps between 2x6s "studs"!!
So here's a question for you guys: why would someone build a wall by nailing hundreds of 2x6s together (like this -->||||||||||||) with absolutely no gaps anywhere along the length of the wall? To put it another way, the builder just nailed studs together on flat, one after another until the wall was finished.
The wall I'm talking about is in an Elementary school built in 1954, so I assume the builders were somewhat professional.
I'm just curious if this is, or was, a legitimate framing method, and if so, what's the purpose of it? I've never seen anything like it before.
VCH250 is offline   Reply With Quote
Old 07-10-2011, 06:46 AM   #2
DIY staff
Rewards Points: 7,174
A picture is worth a thousand words -----
I ran into a wall built out of cross lapped 1" slabs.about 6 layers--it looked like lattice work under a deck.
House was built in 1864 --with 3 major additions over the years.
Old 07-10-2011, 07:39 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
Maybe they were trying to make the wall kid proof. Some kids can tear up an anvil with a powder puff.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-10-2011, 08:04 AM   #4
Rewards Points: 5,336
Much harder for the wall to burn like that. Outer edges will char, but the wall won't collapse until long after the area is evacuated.
Odd that wood was used at all. My elementry school was built in 1954 in Queens, NY. No wood in that construction.
Where is this located?
Ron
B. Franklin 1759
Old 07-10-2011, 04:39 PM   #5
I don't have access to the school right now. The wall looks something like this
except obviously with studs instead of logs.
The wall is an interior one with a second floor above. A stair-case is about 10 feet away from the wall.
The building is located about midway up British Columbia (Canada) in Williams Lake. All schools in the area, except the most modern ones, are built with wood studs.
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
