Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-08-2007, 07:34 PM   #1
Question
Wall furnace blowing out
I have an old 30K+ BTU direct vent wall furnace that keeps going out. It will come on with the flame a nice strong blue color. Then, a moment later, all the flames turn orange and start to waver. This goes on for about 10 seconds then the flame goes out. Is this the valve not putting out enough gas or what? Gas flow to pilot is fine.
kwoodsong is offline   Reply With Quote
Old 12-08-2007, 10:50 PM   #2
You can buy a meter for $80.00 - $160.00 to check the gas pressure. Or you can call a qualified tech which is your best bet. This isn't something a DIYer wants to mess with.
Buckeyetech is offline   Reply With Quote
Old 12-09-2007, 12:29 AM   #3
I know my gas pressure to the valve is fine as the other appliances run properly. I removed the burner and cleaned it thoroughly. There is about a 1" gap between the gas line coming from the valve to the entrance to the burner. Could too much air be getting sucked in there and disturbing the flow of gas?
Old 12-09-2007, 07:11 AM   #4
I doubt it very much. That's the way it was designed.
Old 12-09-2007, 03:04 PM   #5
is this in pilot mode or burn mode??
Suspecting it is pilot mode and you 'may' have a bad or malfunctioning thermocoupler. That thermostat looking thing that is in the pilot flame to keep the pilot lit. IF it malfunctions it shuts off the gas supply to the pilot as a safety. Easy enough to replace and while its off blow out the pilot gas line to be sure dirt or spiders havent nested in there in the off season!!
IF its in the burn mode,,suspect a bad gas valve,,its about all there is between the gas line and the burner!!
IF that doesnt solve it better have a tech come look!!
justdon is offline   Reply With Quote
Old 12-09-2007, 07:14 PM   #6
No, defintely not in "pilot" mode (burner would not come on). The possibility of a malfunctioning thermocouple is interesting except the fact that the pilot has no problem staying lit.
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 05:05 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Wall Furnace change-out Calhoun HVAC 1 11-11-2006 12:01 AM
