Wall Falling Down - General DIY Discussions - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 07:48 AM   #31
DIY staff
Rewards Points: 7,174
No pictures yet---??? No further discussion without pictures.
Old 01-09-2012, 07:50 AM   #32
Ok try getting pics up
rcarey1 is offline   Reply With Quote
Old 01-09-2012, 07:56 AM   #33
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,042
Originally Posted by rcarey1 View Post
It was not the full car just the door
Ayuh,... The door carries the momentum of the car...
I'm quite sure the impact from the car was Much Greater than you give it credit for....
Bondo is online now   Reply With Quote
Old 01-09-2012, 08:09 AM   #34
kwikfishron's Avatar
Rewards Points: 396
Call your insurance agent.
kwikfishron is online now   Reply With Quote
Old 01-09-2012, 12:01 PM   #35
Crusty Old Dude
Big Stud's Avatar
I am not gonna hold my breath waiting for pics
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 01-10-2012, 10:21 PM   #36
Well, sounds like you need a new wall.
chrisBC is offline   Reply With Quote
Old 01-13-2012, 12:24 PM   #37
Old 01-13-2012, 01:22 PM   #38
Rewards Points: 1,294
Yep, hitting that with a car will knock that down, good mortar or bad. You indicated that the car door hit this while the car was rolling backwards and I don't doubt it. I probably could have knocked that down by pulling on it with my hands. The brick is purly decorative and not designed to handle a large object running into it. The way it should have been built to withstand getting ran into would be to eithe pour a concrete core to brick around or put up a cement block core with reinforcing steel in it. Either way will work better than what was there but still not stop a whole lot of force. Time to clean up the mess and get on with whatever you decide to do to replace it. Aside from the poor looking mortar I doubt you would have much recourse on the builder
danpik is offline   Reply With Quote
Old 01-13-2012, 02:27 PM   #39
There ya go pics
Old 01-13-2012, 02:30 PM   #40
But you do agree that the mortor is bad
Old 01-13-2012, 04:02 PM   #41
concretemasonry's Avatar
Rewards Points: 2,594
The mortar has nothing to do with the problem.
Any blind or uncontrolled person can hit that and cause the damage. It has to do with the design and construction determination of the person that decided to buy the structure.
Ever heard of insurance and deductible?
Dick
concretemasonry is online now   Reply With Quote
Old 01-13-2012, 04:36 PM   #42
Bondo's Avatar
There ya go pics
Ayuh,.... It was decorative, Ya ran into it with the car,...
It broke, 'n now needs fixin'....
What was the Question again,..??
As noted before, if it had been core filled with concrete, 'n steel, it mighta stood up to the abuse...
Old 01-14-2012, 07:24 AM   #43
Getting There
MecGen's Avatar
No, you have some bricks that are broken in half...
MecGen is offline   Reply With Quote
Old 01-14-2012, 08:40 AM   #44
Anyway of knowing what bricks.these are like serial.numbers and things like that. And if so we're can I find them it's only four bricks I need to replace.
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
