Wall Falling Down - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 04:38 PM   #16
Civil Engineer
Rewards Points: 4,700
Clearly this is some sort of southern style humor. Maybe you can post a little limerick to go with your report? Maybe a haiku? I mean, of all the bizarre posts we get on this forum, this one is surely right up there, along with the guy who wanted to dig a basement using home made explosives.
Old 01-08-2012, 04:53 PM   #17
Ok I am being serious and now I feel like u being made a joke of
rcarey1 is offline   Reply With Quote
Old 01-08-2012, 05:36 PM   #18
Rewards Points: 1,294
Well , it might seem like you are being made fun of. However, we realy don't know what you want and the less than stellar gramar and sentence structure makes any ability to make sense of what you are asking almost imposible. Start over by showing us some pictures with clear descriptions of what you are seeking to know
danpik is offline   Reply With Quote
Old 01-08-2012, 05:47 PM   #19
Rewards Points: 268
Some of us don't speak "text" shorthand. While my spelling and grammar are not perfect, I try to use complete sentences. Compile your post as you would a spoken conversation and don't leave out the syntax.
packer_rich is offline   Reply With Quote
Old 01-08-2012, 05:55 PM   #20
When the walls came tumbling down. when the walls
mudbone is offline   Reply With Quote
Old 01-08-2012, 06:32 PM   #21
Oh, Oh, Oh. Pick me, pick me... John Mellencamp from his 1983 album Uh-Huh
Old 01-08-2012, 09:41 PM   #22
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
And just why is this some SOUTHERN style humor, don't y'all have idiots up there also?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
jbfan (01-08-2012)
Old 01-09-2012, 01:21 AM   #23
Ok let me start over. Over the last year or so I have noticed that the mortor between the bricks is all falling out which is fine ya would think only the fact that if you put your hand in between it ya can take it out. Now the wall is.a red brick wall and is only about five years old. What I wondering is that with only the car door tipping off the centre pillar which stands alone between my house and my neighbours, is the fact it fall down so easy due.to the mortor as there is nearly no damage at all to my car door. I hope this a bit more sense.
Old 01-09-2012, 05:24 AM   #24
OK, This is not fine. Mortar is what holds the bricks together.
Normaly it would take a chisle and hammer to remove the mortar.
A red brick wall by itself built properly should stand on its own. However, the red brick should be over a heavier core cement block center for additional strength. Red brick is usually a decorative covering.
Not sure what you mean by this. Do you mean the car door was hitting the wall when you opened it?
Most likely. I would still like to see some pictures of the situation as I do not have much to go on here as to where the wall is located, how it was constructed Etc. Sinse we are not there, we need as much information as possible.
Still could use more information but it was definatly easier to read and figure out what you are trying to say.
Thanks for the update
Old 01-09-2012, 06:47 AM   #25
the car rolled down the drive way with the door open a slight bit, and hit the wall with the inside of the door. The Red brick is the only brick there was when I looked down the centre of the pillar they seem to have used wooden planks to hold it together or to keep it striaght on the inside. But on closer inspection this pieces of wood were rotten and fall apart. Like just putting a picture will only show the pillar lying on the ground with all the broken bits all over the ground. The fact that if the mortor is my hands i can break it up very easy its more like sand if you can get what i am trying to say. But As the it was falling it fell from the very bottom and toppled over but it was not hit from very bottom may a little up. I trying to figure out if the the pillar was in the ground was put in right or is the mix in the mortor was right. What I trying to figure out if the bulider is responiable with all that i mentioned or is it the car that is the may cause with it barley tipping it. Again I hope this make sense.
Old 01-09-2012, 06:59 AM   #26
Concrete & Masonry
Rewards Points: 548
Here's the only question you need to answer:
Would the brick column be laying on the ground right now w/o being impacted??
Obviously no.
Who's column is this anyways, your's, a neighbors, a landlords???
jomama45 is offline   Reply With Quote
Old 01-09-2012, 07:05 AM   #27
between two of us the neighbours and mine. But what I trying to figure out is that was a wheelie bin full to the brim would do the same sure would it not
Old 01-09-2012, 07:11 AM   #28
Concrete & Masonry
Rewards Points: 548
Well, let's think about that for a minute...................
100# garbage can???? vs. a 3000# car???????
Pretty sure the garbage can isn't going to do the same damage......................
Old 01-09-2012, 07:20 AM   #29
DIY staff
Rewards Points: 7,174
You need to contact a local mason---in Ireland?
Without pictures this post is not going to be helpful---how is anyone going to help when you have no idea what you are looking at yourself?
Old 01-09-2012, 07:42 AM   #30
It was not the full car just the door
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
