Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-23-2011, 06:17 PM   #1
wall condensation
Outside of 1 basement wall ge ts moisture marks on it by heating ducts
eric8221 is offline   Reply With Quote
Old 03-23-2011, 06:24 PM   #2
Experienced
Jackofall1's Avatar
wall condensation
Hello and welcome Eric, to the best DIY'r site on the web.
I think you would have to be a bit more specific with your questions to get a qualified answer. Pictures really help.
Mark
Old 03-23-2011, 08:09 PM   #3
wall condensation
My heating ducts run over to that wall and up and are in a drop ceiling now I get water or condation marks on outside block above ground level but nowhere else on block walls and will this be a issue also no problem in summer seems only in winter anybody help me?
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
