Wall AC Unit - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-27-2012, 10:27 AM   #1
Wall AC Unit
Okay, here is my dilemma. I have purchased a home that has an old Air Conditioning Wall Unit that is inserted in a very awkward location in the living room. I have recently installed a heat pump system so the old Wall AC unit is no longer needed. I would like to remove the Wall AC unit and fill the void in the wall. The inside of the house repair (drywall, tape, mud, etc.) is not the issue. The issue is on the outside. I have aluminum siding on the outside of the house that was cut when the Wall AC unit was installed. I was not left any extra siding when I purchased the home. How do i repair the outside of the house?
pbcleff is offline   Reply With Quote
Old 09-27-2012, 10:37 AM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Remove AC unit,remove the siding on the outside wall on both sides of the hole.
Add 2x4 studs in the hole.apply plywood to outside along with vapor barrier,replace siding with longer pieces.
sublime2 is offline   Reply With Quote
Old 09-27-2012, 11:18 AM   #3
How would I be able to match up the siding by size and color? The aluminum siding is about 40 years old so I would think I would have a hard time matching them.
Old 09-27-2012, 11:33 AM   #4
Bombastic Idiot
notmrjohn's Avatar
Remove some siding from some less conspicuos place on home. Down low, behind shrubs, somewhere else? Replace that with as close a match as you can find. Have you looked for match? Mite be surprized, some styles, patterns still around after more than 40 years. If something sells, don't mess with success.
When patching AC hole, and canabalized pieces, do not use all same length pieces. Stagger joints, Some joints should be several feet from patch, some may be right in center of patch. No joints should be directly over seams or joints in patch or vapor barrier.
Your home is a treasure trove of parts for other projects. Tho some family members may object when they discover open hole where window used to be.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-27-2012, 11:53 AM   #5
Would Home Depot or Lowes be a smart place to look for a match or would I be better going to a company directly?
Old 09-27-2012, 03:09 PM   #6
Bombastic Idiot
notmrjohn's Avatar
Start at big boxes, then to local siding companies, then suppliers, makers. How about a photo of siding? especially show profile, some one may recognize it.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Fujitsu Halcyon AC wall unit dribbling water out of vents Big Murth HVAC 2 07-03-2010 02:50 PM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 10:07 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
