Walking On An Aluminum Flat Roof - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-24-2014, 11:52 AM   #1
Rewards Points: 8
Walking on an aluminum flat roof
I need to do some painting on a gable that butts against a flat aluminum roof over a screen porch. Will an aluminum flat roof over a screen porch hold a 200 lb man? What if I put a piece of plywood over the ridges to stand on? If not, any suggestions for building a scaffolding or how to do the painting?
herbie69? is offline   Reply With Quote
Old 12-24-2014, 12:03 PM   #2
Low Slope Roofing
Rewards Points: 1,184
Is it an ribbed panel? What is holding the panels up rafters/decking? Got a picture.
If it's a standard wood framed structure with a exposed fastener roof then maybe if it has plywood decking, if it's just thin panels over rafters then you can but have to stand over the rafters.
Now if it's a thin panel aluminum manufactured sun room I wouldn't stand on a number of those.
1985gt is offline   Reply With Quote
Old 12-24-2014, 12:05 PM   #3
joed's Avatar
Rewards Points: 4,044
Depends what is under the aluminum. If this is just a light porch awning then probably not. If this a full roof with rafters etc. probably it will support you.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-24-2014, 12:14 PM   #4
Rewards Points: 8
It is a manufactured sun room. The roof has ribbed panels with raised "seams". The panels are about 16 feet in length supported on the edges by the aluminum framed screen wall.
So, I guess my best bet is to build some sort of scaffolding. This is a real challenge. It leaks in heavy rain (where it is against the wall).. which is why I want to caulk. Maybe, I should just tear the darn thing off and sell the aluminum for recycling.
Old 12-24-2014, 12:20 PM   #5
Low Slope Roofing
With out a picture no one could say for sure, even then it's iffy. From the sounds of it I would not walk on that roof. To be honest the people who install them do not always have a good grasp of what flashing and counter flashing are.
If it's in real bad shape maybe tearing it down and building one wood framed may be a good option.
Old 12-24-2014, 02:13 PM   #6
Rewards Points: 8
Thanks. I have fought leaks on this aluminum roof for years. Probably should bite the bullet and frame out a wooden structure. Problem with wood frame is the pitch of the house roof. I would have to dig into the shingles higher up for the start point (have had expensive estimates for this option), or go with another flat roof (which I really don't want). Maybe I will rent a cherry picker to get me over to do the caulking and painting.
Old 12-24-2014, 03:35 PM   #7
Low Slope Roofing
"flat" roofs are just fine if done correctly. Tie-in to shingles isn't a big deal either, again if it's done correctly.
Good luck
Old 12-25-2014, 12:17 AM   #8
pmd
Rewards Points: 6
Herbie, do not walk on the aluminum roof. It is not a structural roof and you will ruin the aluminum roof pans. The roof pans are manufactured out of .024 or .032 aluminum coil and formed into the raised rib pan.
It sounds as though you have a florida screen room. To access the area above the aluminum room you can use a walkboard supported on both sides of the structure with ladders, therefore not putting any weight on the screen rooms aluminum roof.
Just check your local rental for a Werner Aluminum Walkboard, they are normally 24' or 30'. You will also need two ladders with the attachments for the walkboard.
pmd is offline   Reply With Quote
Old 12-25-2014, 11:50 AM   #9
Household Handyman
Rewards Points: 1,106
Well, I've had to do this before and here's how I have successfully done this: I use what I know to be a "dead man" under the aluminum panels of the roof and a piced of 4x4 plywood on the top to distribute the weight (I'm a bit over 200). The dead man is nothing more than a 2x4 lying horizontal nailed to the top of a vertical 2x4 and the dimensions of this dead man are exact so that it fits snug between the concrete floor and the underside of the panels. This dead man must be moved as you move across the top of the roof to do your painting or--you can build more than one dead man to support the roof so you can just move the plywood as you need to. Hopefully this will work in your case.
extend roof over flat roof nate1582 Roofing/Siding 16 05-21-2012 12:35 PM
Insulating flat roof deck paredown Insulation 0 05-15-2012 05:33 PM
Flat roof related questions christy123 Roofing/Siding 8 12-10-2008 12:30 AM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 06:48 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 09:34 PM
