Vinyl Soffit - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-03-2012, 02:44 PM   #1
Vinyl soffit
Soffit and fascia blew off the gable of the house in the storm... Was wondering if anybody knew where I could find or at least the name of this type of soffit...it has the usual wood grain surface but has a uniform 'v' in the center of a double 6" soffit. Thank you
stoked91 is offline   Reply With Quote
Old 11-03-2012, 02:52 PM   #2
kwikfishron's Avatar
Rewards Points: 176
Good luck with that one. I've never seen a D6 vinyl soffit before, aluminum yes but not vinyl. In fact i've never seen vinyl soffit quite profiled like that either.
kwikfishron is offline   Reply With Quote
Old 11-03-2012, 04:14 PM   #3
Rewards Points: 2,238
That looks like "Vertical", vinyl siding - not soffit.
I've never seen vinyl, soffit that looked quite like that!
If you can't find something to match - try re-using it.
"RF"
rossfingal is offline   Reply With Quote
Old 11-03-2012, 04:28 PM   #4
Rewards Points: 13,270
Ditto, if it's not broken then just put it back up and nail it back in place.
99% of the time when I see fasia fall off it's because no one nail it in where it's bent to hold up the soffit.
I have a special punch that makes an oval hole that's sized for trim nails.
Can not tell you how many time when it falls off the home owner has tryed to reattach the fashia with roofing nails, not pretty.
Do you have vinyl preformed fashias, if so there's the main reason it fell off. That stuff is junk.
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing/Siding 18 05-29-2012 10:12 AM
Hardware for Vinyl Soffit stymie222 Building & Construction 8 04-22-2012 11:08 AM
vinyl Siding / Soffit Question J S Machine Building & Construction 42 04-18-2011 11:11 PM
Vinyl soffit and fascia msyv Building & Construction 7 09-13-2009 11:21 PM
Vinyl Soffit man117 Building & Construction 4 11-11-2008 06:53 PM
