Vinyl Siding And A Mailbox - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-26-2010, 04:19 PM   #1
Vinyl Siding and a Mailbox
Hi,
Allow me to preface this by saying that I am not in the slightest handy. I am trying my best to do things myself. I have mailbox that I'd like to attach to my house. My house has vinyl siding. I've checked this forum and found a thread that somewhat answers my question. But I feel it was not enough information.
How do I know if I have wood or "foam" behind the siding? I've attempted to move the siding from the house as far as it can go and it looks like there is some sort of paper, which I assume is the "foam". If this is the case, how do I go about finding a stud to attach the screws? Does an everyday, run-of-the-mill stud finder do the trick with siding?
I have faux shutters on the sides of my windows that I was going to use as a basis as to where a beam was and then I thought better and figured it was attached to a beam going up and down and not across.
If a beam is and can be found, will simple wood screws suffice for hanging the mailbox? Or will I need to use something else to ensure it stays?
For something so simple, I feel that I can easily screw this up. Please help. Thanks!
Altutor is offline   Reply With Quote
Old 04-26-2010, 06:51 PM   #2
Rewards Points: 5,336
Forget the beam, forget the faux shutters. They sell mounting blocks for siding you can use to mount lights, outlets, etc.. Pick up two the size you need and just screw them through the siding into the sheathing. Screw the mailbox to the blocking.
Ron
Old 04-27-2010, 10:10 AM   #3
Ron,
Thank you very much. I will look into the mounting blocks today at my local Lowes. Will everyday wood screws be the best bet for attaching the mounting block? And should I pre-drill a hole through the siding?
Old 04-27-2010, 11:33 AM   #4
You want to predrill the holes and apply a caulk around and in the hole so water doesn't get into the house. You want to use a screw that will not rust, either a deck screw or stainless steel.
Home Depot carries the blocks that can be mounted on installed siding. They have square blocks that are 6 1/2" x6 1/2". They also carry octagonal blocks about the same size. I don't know if Lowes has them
Ron
Old 04-27-2010, 01:43 PM   #5
Thanks once again for the help!!!
Old 04-27-2010, 03:02 PM   #6
funny how something so simply can get you
Be sure to specify you need the mounting block for "pre-installed siding". Ron referenced this but I wanted to make sure you caught it. These blocks will have a notch on the back profile that allows it to sit flush against the siding.
here is a random example of what it might look like
http://www.a1components.com/itemdisplayn.aspx?item=10603
You still need to screw the mounting block in. This brings you right back to your original dilemma "How do I know if I have wood or "foam" behind the siding?" .
I would use a simple tool to pop up a course of siding and then probe underneath to see what the sheathing was (wood or foam). Depending on the age of the home the foam you think you see could just be 1/4 inch fan fold foam that is used to create a flat surface for siding installs. Behind that fan fold could be wood, cement shingle etc..
example:
http://www.acehardware.com/product/i...LAID=109366794
I had an older home, 1950's, that I sided years ago. It had a shingle on it originally. I hung a mailbox just as you are doing, no mounting block, just had two screws directly into the siding and hung the mailbox on the key hole mounts. I knew what I was screwing into though.
sorry if I made it worse.
ferris13 is offline   Reply With Quote
Old 04-28-2010, 03:53 PM   #7
Thanks Gents! I will give this a whirl and let you know how it comes out!
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
