Vinyl Quarter Round Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 04:35 PM   #1
Vinyl quarter round question
I'm redoing the back porch on my house. The previous owners had enclosed it making like a sunroom out of it. I want to put down some indoor/outdoor carpet, and then put quarter round down. I came across some vinyl quarter round. I've never seen that before, and don't know how you would attach it. Do you nail it? Or is it glued down? Thanks.
phil74501 is offline   Reply With Quote
Old 04-08-2011, 05:09 PM   #2
KemoSabe
loneframer's Avatar
I've used many profiles of vinyl, or PVC trim.
When attaching to another PVC surface, I use a brad nailer, along with some PVC cement to fuse it to the other surface.
If it's being attached to wood, I'd use some adhesive caulk or construction adhesive, along with brad nails. The adhesive will help prevent buckling from expansion of the material due to temperature fluxuations.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 04-08-2011, 05:38 PM   #3
It would be attached to wood. Would adhesive alone work?
Old 04-08-2011, 06:01 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
I would not use an adhesive in that application. In the future you may need to remove to replace the carpet. If it is glued to the base you will tear up both the 1/4 round and the base. I use an 18 gauge brad nailer. nail thru the base into the bottom plate, not into the floor.
Coastal South Carolina
Old 04-08-2011, 06:15 PM   #5
Well I can't nail into the floor, it's concrete.
So nails it is. Thanks
Old 04-08-2011, 06:18 PM   #6
kwikfishron's Avatar
Rewards Points: 1,024
When it buckles off the wall come back and re-read your thread.
kwikfishron is online now   Reply With Quote
Old 04-08-2011, 06:54 PM   #7
Rewards Points: 292
Gotta agree with Ron on this one. A dab of construction adhesive every 10-12 inches and nails to hold it in place while the adhesive sets up. If you don't use an excessive amount of adhesive, it should not give you too much of a fight to remove it in the future.
I have used silcone on PVC cove molding in my bathroom as an adhesive. Same thing a dab periodically. A continuous bead is excessive IMO.
Jim F is offline   Reply With Quote
Question about vinyl siding bulging and forming bubbles sljacobs Building & Construction 6 03-08-2010 07:17 PM
lap spacing on vinyl siding question DangerMouse Building & Construction 4 04-30-2009 07:32 PM
Quarter round and baseboard justtired Flooring 1 09-30-2006 04:39 PM
Vinyl Siding & windows question blazermaniac General DIY Discussions 6 04-08-2006 12:47 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
