Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-23-2009, 05:46 PM   #1
Default Very Low Hot Water Pressure.
I have very low hot water pressure in my house at all faucets: two bathroom sinks, shower faucet and shower head, and kitchen sink. The cold water pressure is fine. About five months ago I noticed the hot water pressure would decrease sometimes, while other times it would be normal. Now it's always low. I've done the following three things attempting to fix the problem:
1. Drained the water heater by attaching a hose to the drain valve, turning the cold water supply off, and letting the water drain out. I noticed very little sediment in the water.
2. Drained the water heater by attaching a hose to the drain valve, leaving the cold water supply on, and letting the water drain out. I noticed very little sediment in the water.
3. Drained the water heater by attaching a hose to the drain valve, closing the cold water supply valve, opening all the hot water faucets in the house and letting them drain. I noticed a small amount of sediment in the bathtub and nothing in the sinks.
I'm going to backflush the system tonight to see if that works. It's looks like the heat-trap nipple on the hot water supply line may be stuck (corroded) shut.
The water heater is a Richmond made in December 1998. I'm on city water.
If anybody can give me any advice, I'll appreciate it. Plumbing is not one of my strongpoints. Thanks........
PAS1970 is offline   Reply With Quote
Old 02-25-2009, 03:07 PM   #2
Default Old pipes?
The heat trap nipple is a good place to look. But if you have older galvanized water pipes then this could also be the source. The hot water lines tend to corrode inside before the cold. They will act like the artery in a heart and constrict over time due to calcium build up you may need to replace the lines to each fixture. I would do hot and cold at the same time to save from doing the cold in the future. sometimes just a piece will break loose and slow down the whole system. doing the flush may or may not help ive always replaced just because if it happened once it may happen again later. good luck
plumbbum0203 is offline   Reply With Quote
Old 02-25-2009, 05:01 PM   #3
Thumbs up Heat-Trap Nipple
The pipes are copper. I think the hot-side heat-trap nipple is the culprit. From the outside the cold-side heat-trap nipple is new and shiney; the hot-side heat-trap nipple is old and rusty. I've owned the house for about 21 months, so I don't know what the previous owners did. But it seems the cold-side heat-trap nipple has been replaced, so maybe there have been problems in the past. Flushing has produced very little sediment, therefore, I don't think sediment is the problem. Thanks for the reply.
More On This Topic
Today we’re installing a kitchen sink in a rebuilt counter. We already have the sink secured with the braces and everything. The next step that we want to do is to actually install the sink supply lines onto the faucet valves. You want to loosen... Read More »
If you live in a part of the country where the temperature gets down below freezing, you just might run into the problem of having your water or drain pipes freeze. As long as you’re home (and not off vacationing somewhere warm) you can usually fix... Read More »
Fresh water is an absolute must when traveling in an RV. It's important that you know how to clean the existing system through routine maintenance and keep freshwater flowing through your RV's pipes. You also can install additional filters to your RV... Read More »
Using your tankless water heater is as easy as turning on your faucet. Whether you have chosen a gas or electric water heater, using them is the same. Once the tankless water heater is properly installed, you simply turn on the hot water. Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will show you step 1 for installing a ball valve. I am going to be installing a ball valve on this pipe. This pipe is a hot water pipe, and I know that because when I trace it back, it... Read More »
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 03:02 PM
Questions about water pressure regulation.. MrSimmonsSr Plumbing 18 04-24-2009 11:20 PM
Gas Hot Water Heater Tank and Pressure Relief Valve skadoo323 Plumbing 0 01-12-2009 10:52 PM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 04:32 PM
Bad water pressure (well water) fnkyniedls Plumbing 2 10-23-2006 01:42 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
