Venting For Whole House Fan - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 12:08 PM   #1
Rewards Points: 33
(I think I finally have the right forum)
I've been wanting to install a "whole house fan" for some time & almost did once, but the local supplier made a point to tell me I should make sure that the attic is adequately vented before I force air into it. He simply explained that if I did not have enough venting, the fan would be over worked by trying to push more air than the attic vents can handle. It made sense, so I put off doing it until I knew more.
My attic has soffit & ridge vents only, but I could add a gable vent to one end of the house if needed. I've been in houses that have ceiling mounted fans pulling cool air in & I like it. I'd run my A/C a lot less if I could just cool off the house better.
How do I determine what size fan I need as well as whether or not I have enough existing vents?
Thanks in advance for any advice.
Bob Deb is offline   Reply With Quote
Old 11-11-2011, 12:27 PM   #2
Rewards Points: 150
It depends on the fan, you might comb through this site it explains alot.
http://www.wholehousefan.com/FIND/Your-Perfect-Fan.html
josall is offline   Reply With Quote
Old 11-11-2011, 12:51 PM   #3
Experienced
Jackofall1's Avatar
Hello Bob and welcome to the best DIY'r site on the web.
The supplier you mention is full of it, I mean right up to his eye balls full, a fan will only reach its rated static pressure rating by moving air, if there is no where for the air to go then you won't move it. If you don't move the air you don't use the horse power.
The net effect of not having enough vent net free area will reduce the efficiency of the system, there-by adding costs to running a motor that is not providing its design intent.
Personally if you are going to install a whole house fan vent it directly to the out doors, you don't want to pressurize your attic, this will have negative effects on the whole concept.
Mark.
PS you have multiple posts of the same subject please only post once, this way you can track your responses much more easily.
Old 11-11-2011, 01:27 PM   #4
Rewards Points: 5,336
Mount the fan on the gable end, blowing directly outside. Put a shutter in the ceiling the same size as the fan. A 24" fan means a 24" shutter.
When the fan is on, the shutter in the ceiling will open automatically.
In the Winter, cover the ceiling shutter with an insulated box.
Ron
B. Franklin 1759
Old 11-11-2011, 04:50 PM   #5
Rewards Points: 33
Thanks for the replies & link.
After reading some more, it seems that with the large volume of air space in my house due to all the cathedral ceilings, I may not have enough of a venting area with the existing vents in my attic. I did a rough estimate & have about 14,000 cubic feet.
This idea appears best.....
I saw the following photo & description & think something like this set up is what I need.
http://www.airscapefans.com/products...se-Fans/Kohilo
Old 11-11-2011, 09:27 PM   #6
This ducted model will isolate the house from the attic.
Ron
B. Franklin 1759
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Is this enough venting dntsdad Roofing/Siding 2 06-11-2011 11:13 PM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 05:58 PM
