Venting Of A Microwave Oven Into Attic. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-07-2009, 10:58 AM   #1
Venting of a microwave oven into attic.
I just replaced a microwave oven in the kitchen and all went well. I told my wife I wanted to make sure it was venting well so I started to climb on the house to "see"/ "hear"/ "feel" how it was venting/ exhausting from the kitchen. My wife told me that there was no vent that went outside thru the roof-- and she was right. She said the vent was in the attic and again, she was right. Anyway, I went into the attic and saw a nice vent line going from over the microwave up to but not out of the roof. From where I viewed did not see any inside openings on the vent plimbing-- although I did not climb over to the vent and look on the "backside". My question is: should the exhaust vent plumbing be "vented" inside the attic--- ie should there be holes or luvers or a flapper opening where the exhaust fume can escape into the attic? Any replies to this question would be appreciated. I am an older gentelman; but still capable of getting around pretty good.
BobLink is offline   Reply With Quote
Old 09-07-2009, 01:26 PM   #2
Rewards Points: 177
The vent should be vented outside, not into the attic. The make roof vents that accept the vent lines from the microwave.. Also the plumbing vents should also go through the roof.
paul100 is offline   Reply With Quote
Old 09-07-2009, 04:20 PM   #3
Plumbing vents should 100% go either thru the roof or out & up a wall beyond the roof line
Microwave vent should also exit the attic
Exhaust does contain moisture & you do not want to exhaust moisture into the attic
venting metal roof for attic conversion nelsonC Roofing/Siding 14 01-21-2010 02:32 AM
Attic venting options Bob_T Roofing/Siding 5 06-20-2009 05:54 PM
Above Oven Microwave Oven - Maganatron Burned Out chats72 Electrical 7 12-31-2008 01:19 PM
Blocked Attic Soffit Vents on North Side - How to Improve Venting Jes Roofing/Siding 5 05-06-2008 09:35 AM
Attic Fan Venting joedadog Building & Construction 2 02-02-2007 06:05 AM
