Venting Furnace & Water Heater - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-24-2009, 05:01 PM   #1
venting furnace & water heater
Can I run my gas water heater and my gas high efficiency heater through the same vent?
tcoly is offline   Reply With Quote
Old 11-24-2009, 05:13 PM   #2
Rewards Points: 5,336
These devices come with instructions. What do they say?
Ron
Old 11-24-2009, 05:36 PM   #3
They were installed by the previous owner.
Old 11-24-2009, 07:21 PM   #4
The units have instruction, no matter who installed them. If the manuals are not in the house, the manuals are usually available from the manufacturer. These can usually be accessed and downloaded from the internet.
Ron
Old 12-15-2009, 05:08 PM   #5
Phil
You probably do not have a high efficiency furnace if it is vented to the roof along with your water heater. True high efficiency furnaces produce condensate which must be vented out through a wall using ABS or PVC pipe. With such condensing furnaces the intake and outflow lines need to be done properly to keep flue gases from being drawn into the house.
Your furnace may be an 80% unit with a variable speed motor to make it more efficient but it is still a 80% furnace and not one of the new 90-95% efficient designs (which can cost twice as much to buy and install).
Phillysun is offline   Reply With Quote
Old 12-15-2009, 05:41 PM   #6
Chicago, IL
Michael Thomas's Avatar
If an appliance is venting through a PVC (plastic) pipe, it usually requires a individual dedicated exhaust vent - common or breach venting will be prohibited in the manufacturer's installation instructions. (Many such appliances can vent through either a roof or wall, BTW).
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Tankless water heater to pre-heat incoming water matthet Plumbing 35 01-06-2017 01:39 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
water pooling ontop of water heater nannerkrns Plumbing 2 09-23-2008 11:04 PM
Converting from furnace to how water heater skittlzski Plumbing 2 05-16-2008 11:10 AM
Venting a gas water heater renovation07 Plumbing 7 01-02-2008 10:46 PM
