Venting A Dryer In A Chimney - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 04:11 PM   #1
Rewards Points: 264
Venting a dryer in a chimney
I want to vent my dryer into my chimney, but am worried about lint building up.
Can I just put a duct filter to trap the lint?
The chimney is only used to vent gas appliances, but still, I don't want to fill it with lint.
tibberous is offline   Reply With Quote
Old 01-31-2012, 04:23 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
You can't just put a filter on the line - you will clog up the line to the dryer. Dryer vents need to be free flowing with no obstructions (like screws or screens) for lint to collect.
I think your only choice, and probably only code-legal option, is to vent the dryer outside properly on its own line.
hyunelan2 is offline   Reply With Quote
Old 01-31-2012, 04:27 PM   #3
Rewards Points: 2,212
Please do not vent the dryer into the chimney.
Where is the dryer located? Why can't you go out a wall?
mae-ling is offline   Reply With Quote
Old 01-31-2012, 05:00 PM   #4
Rewards Points: 264
Center of the room in the basement. The layout is tight, but it is the only way I could fit a bathroom, a kitchen/laundry (technically one room), a bedroom and a living room all in my basement (plus the boiler, hot water heater, ect)
Big problem is that the basement has a bunch of columns that hold up the house, and HUGE chimney, and a staircase. There aren't many ways to layout the room.
What about just using a screen instead of a filter? More airflow, should still catch a lot of lint?
Old 01-31-2012, 05:25 PM   #5
Rewards Points: 13,750
Just forget about that idea. Totally illegal, a fire hazard, may cause a fire or reliece toxic fumes.
That dryer never should have been installed in the middle of the house, long runs for venting are a sure way to have trouble.
Old 01-31-2012, 07:28 PM   #6
Rewards Points: 264
What about something like this?
http://www.amazon.com/Dundas-Jafine-...p_ob_e_title_0
Old 01-31-2012, 07:33 PM   #7
Hmm hot moist air blowing into the basement, not a great idea.
Old 01-31-2012, 08:00 PM   #8
Rewards Points: 264
Yeah - you could run a vent fan, but then it's pretty much the same as venting it in the chimney with a screen.
Old 01-31-2012, 08:05 PM   #9
Rewards Points: 582
ther should be a way to get that dryer vented to the out side wall...you may need to get a professional out for a look..Ben yes forget about the chimney
Old 01-31-2012, 08:32 PM   #10
Rewards Points: 1,298
Lint is only one of the problems to overcome. The othe two are CO and moisture. Moist air venting into the chimney at that level will cause sweating and staining of walls when it condenses out. The bigger and potentialy deadly problem is when the dryer is venting into the chimney. The dryer vents with pressure. This presure in the chimney will disrupt the natural draft that other appliances need to function properly and draw out deadly CO. Whenever the dryer is running the furnace and water heater will potentialy be venting into the house
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
ben's plumbing (01-31-2012)
Old 01-31-2012, 09:12 PM   #11
Rewards Points: 264
Does natural gas make enough CO to matter? My fireplace isn't even vented, either is my stove.
I know gas increases co2 and I think it depletes oxygen, but I thought co was only really an issue with wood?
Old 01-31-2012, 09:17 PM   #12
Rewards Points: 264
If I did run a duct, any idea how big it would need to be? I could put one between the joists, but it's like a 10 foot run - I'm afraid it condenses in the duct and drips down.
Can you vent into 4" PVC? Because I could exhaust into PVC and slope it so the condensation ran either outside or into the plumbing.
Old 01-31-2012, 10:16 PM   #13
hyunelan2's Avatar
Rewards Points: 692
People DIE quite often from CO related gas appliances - usually furnaces. Natural gas is probably the #1 CO killer.
You can't use pvc. The static generated will cause lint to stick. 4" metal ducting is the way to go. I don't think a 10' run would be much of a problem. If concerned about condensation, slope the duct appropriately.
The Following User Says Thank You to hyunelan2 For This Useful Post:
mae-ling (01-31-2012)
Old 01-31-2012, 10:20 PM   #14
And you can insulate it also
Old 01-31-2012, 10:45 PM   #15
Registered User
Rewards Points: 5,520
Just have to repeat, it's so important: only smooth-wall metal duct- 4" minimum, it's own use, foil tape the joints- no screws, use a Type "A" termination hood for 50% more air-flow there: http://www.appliance411.com/faq/dryer-vent-length.shtml
Exhaust +3' from other house openings- pp.31-33; http://www.ci.broomfield.co.us/build...andout0308.pdf
Basics: http://www.ashireporter.org/articles...es.aspx?id=161
Just the facts; http://www.ashireporter.org/articles...es.aspx?id=161
Number 10 of the "Top 10": http://www.buildingscience.com/docum...ong-from-start
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
KatHelms (02-17-2012)
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Need some advice on venting a dryer. John_W Building & Construction 9 06-26-2011 10:34 PM
Dryer Venting Question cbzdel HVAC 4 05-18-2011 02:16 PM
gas hot water tank venting in chimney w no furnace... dbldee20 HVAC 5 02-25-2011 08:21 AM
Venting a dryer through old chimney CarpentersKid General DIY Discussions 6 08-04-2009 02:22 PM
